Is my build compatible, enough wattage, good cooling, etc.
noah978
4
Hello everyone,
I simply would like To check the compatibility on my build found at the link below. I also would like to know whether you would suggest the Phanteks enthoo pro full tower as a good case. I am planning on doing an SLI in the future and possibly additional or upgrading water cooling. Which is why I want to know if the 550 gold I have is enough or the 750 watt is necessary. Thanks.
LINK: https://pcpartpicker.com/list/QsKyTH
I would go with a 1080ti over trying to SLI 2 1070 cards, you can run into issues trying to SLI with games as they don't always work properly.
OK, thanks. I didn't know that the SLI system didn't work with all games, I thought it worked universally if you set it up right.
