Is my CPU cooler overkill?
jimmygongers
Commendable
Jul 10, 2016
14
Is a Corsair h115i overkill for an i5-6600k? If it is overkill I will prob go with a corsair h60?Also I will be trying to overclock the cpu by the way.
D
My 6700K takes 1.35v for 4.6Ghz and my Phanteks PH TC14PE keeps the cores under 70C unless I run Prime 95 small FFTs and Intel Burn Test at the same time. Then one core breaks 70-71c. The H115i is overkill. Skylake chips hit an overclock wall well before temps become an issue even with air cooling.
@jtk2515 I would like to oc it to atleast 4.5 but can I go for 4.6/4.7? Also what's the max ghz the 6600k can go up to?
I want my cpu liquid cooled though. lol
So back to my question, the h155i is good for overclocking to that speed? And if I had a h60 and I wanted to overclock it it could not handle it?
Out of curiousity, what about the 110i gtx? Also whats the maximum ghz I can get on the 6600k?
That would be good aswell.
EDIT: The 6600k can hit 4.6 easily.
Depends on your luck. I got 5ghz out of my 6700k at 1.45vcore. I have a swiftech 220x2 and i hit 75C 78C spike
