[SOLVED] Is my CPU fried? NEED HELP ASAP
Dec 29, 2018
Long story short, I put in my Intel Core i3 and my pins on my MSI B360 Gaming Plus were bent. My newly built PC wouldn’t boot up. I can buy a motherboard but I’m just worried about my CPU. Is it fried or just discolored?
pnPrylq
CPU may not be fried. Borrow a motherboard with the same chipset and try out the CPU. Worst case is it will just not boot up. Or find a local PC hardware store that tests and troubleshoots and ask if you can test your CPU.
Will that ruin my other motherboard if it is fried?
No. At worst, it simply wouldn't work.
Do you know if electronic stores like Frys test out processors?
Latest posts
