Is my display in 32 bit or 64 bit?
christianelliott
91
Hey,
I recently built a pc for gaming, and loaded windows 7 64bit home premium onto it. i have a 6800 series graphics card from amd, and its pretty old, actually used, got it from a friend. it seems to run ok, and after installing old drivers from a disk, got new ones from amds site. when i go to desktop properties in ccc though, it says i have a 32 bit 1080p monitor or whatever, and i have win 64bit. is my computer really utilising the 64bit, or is it running in 32bit?
thanks
Your mixing things up :) 32bit/64bit only refers to your OS. the 32bit on a monitor, refers to the colour depth, as opposed to the 32/64bit OS. Different things altogether.
Don't; worry your monitor should be using 32 bit as default.
