[SOLVED] Is my GTX 1660 Super power consumption correct ?
May 31, 2021
16
Recently my graphics card suffered a short circuit and I sent it to repair, so far it has worked perfectly but I was monitoring with HWinfo64 and I noticed that in the data of "GPU Rails Power" marks as 132.235w and "GPU Power" marks as 118.942w the maximum value, is this normal?
I leave here the screenshot of HWinfo (the screenshot I made after playing) and I need to know if all the values are correct or there may be a problem?
The TDP of the GPU is 125W, your particular GPU might need a little more depending on the design of the card but I calculate a 5.44747% difference between the GPU rails and the TDP of the card. If you went with the GPU power and the GPU TDP, you get close to 5% in difference. You're fine, considering you got it repaired and that the card is doing what you're asking it to do(?).
