S Shaneman1114 Jul 17, 2019 3 0 10 Jul 17, 2019 #1 My Hp Z230's 698113-001 or 698114-001 (not sure) mother board says on websites that it is an ATX board. But not sure if i can simply plop it into a standard case. Any one with experience or a way i can find out?
Solution Satan-IR Jul 17, 2019 I'm not sure as those boards are proprietary designs and the case back plate for them might have mounting holes in different positions. I think it's best if you give HP support people the exact part/model number of the motherboard you have and check with them. You can also wait and see if anyone here with more input on this chimes in.
Satan-IR Splendid Ambassador Apr 18, 2014 2,427 407 21,390 Jul 17, 2019 #2 If the HP website says it's ATX it should have standard mounting holes and would go into any ATX-compatible case. Is it this one or this one? Reactions: Shaneman1114 Upvote 1 Downvote
S Shaneman1114 Jul 17, 2019 3 0 10 Jul 17, 2019 #3 Satan-IR said: If the HP website says it's ATX it should have standard mounting holes and would go into any ATX-compatible case. Is it this one or this one? Click to expand... Oh thanks ! Its the 698113-001 (the second link) Upvote 0 Downvote
Satan-IR Splendid Ambassador Apr 18, 2014 2,427 407 21,390 Jul 17, 2019 Solution #4 I'm not sure as those boards are proprietary designs and the case back plate for them might have mounting holes in different positions. I think it's best if you give HP support people the exact part/model number of the motherboard you have and check with them. You can also wait and see if anyone here with more input on this chimes in. Upvote 0 Downvote Solution
