Question Is my maximum GPU temperature okay?
qlamunja
Commendable
May 10, 2022
13
So I have been monitoring GPU temperature via hwinfo and I have noticed that an average temperature is somewhere between 50-54 and maximum is 65 and 67 was the highest it ever got (I'd assume it is during heavy load since I mostly play bethesda games and recently fo4 was a mess when it comes to performance). Should I be concerned or is it below normal? and what temps are normal for gpu during gaming anyway?
if you mean you are idling at 50+° with nothing going on that is higher than i would allow, but not dangerous in any way whatsoever.
i usually aim for ~30-35° while the system is idling or in low usage scenarios.
reaching 65-67° with max loads is pretty average these days.
i try to keep mine ~60° max, but again what you are seeing is nowhere near dangerous.
Reactions: madaraosenpai
when idle it's just like that, around 30c
As long as you aren't peaking above 80 celcius you are probably fine. 90+ is the danger zone. Newer GPUs are becoming more tolerant to heat. And prolonged overheating is more dangerous, if you peak above the 80° threshold rarely but don't stay above it then you're probably going to be fine.
For a much older card (pre Kepler) you definitely want to stay below 70.
Latest posts
