Is my motherboard not compatible with my case?
kevinbas23
Hello
For a couple months now I have noticed that my Acer predator g3-710 case doesn’t provid enough air flow for the components inside so I went and bought a crystal 570x from Corsair. When the case arrived, everything started off fine. I installed the memory and hooked up the mother board. I pressed the power button and nothing. I looked a little deeper and saw that there where 4 cables not connected. The powersw cable, power led+, power led-, and the reset cable. I looked at the pictures I took when I did not touch to anything and there where no cables like this. Their was only one cable that had 9 pins on it. If you know what my problem is, can you please tell me the solution .
Thanks a lot, kevin
Latest posts
