is my pc build will work on other components, newbie here.
adriane_1
24
Intel Core i3-4160 3.60GHz (Dual Core)
Gigabyte GA-H81M-Gaming 3
Gskill RipjawsX 8GB Dual 1600 CL9 (F3-12800CL9D-8GBXL)
Western Digital Caviar Blue 1TB WD10EZEX
Zotac GTX 960 AMP! Edition 2GB 128Bit DDR5
Corsair VS450 Power Supply
Cougar Volant Gaming Case
Your Mainboard and CPU are totally compatible but I'm not sure about your memory, you can use this instead:
2x Gskill RipjawsX 4GB 1600 CL9F3-12800CL9S-4GBXL
This is completely compatible.
About your Graphic card, your mainboard supports PCI E 2.0 but you selected a PCI E 3.0 Graphic card, they works but not at the best performance!
For your HDD, I suggest choosing a SSHD storage
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=5177...
http://download.gigabyte.ru/memory/mb_memory_ga-h81m-gaming_3.pdf
50-70 dollars
will this motherboard supports zotac gtx amp??Asus B85M-G..
The graphic card you mentioned is not exact, I found these 3 graphic cards:
https://www.zotac.com/ir/product/compare/graphics_card?id=330023,330025,330026
http://tinypic.com/r/2rgjdsn/9
But the important thing is that all of them have PCI E 3.0 interface and the Asus B85M-G R2.0 also supports PCI E 3.0:
https://www.asus.com/us/Motherboards/B85MG_R20/specifications/
http://tinypic.com/r/2cwu8nm/9
