Ok, so here are my current system specs:
Intel i5-9600k
Rx 580 Gaming x 8g
16 gb of 3200mhz RAM
MSI Z390-A PRO
512gb SATA III SSD
Cooler Master 750 Watt gold+ PSU
I want to get into vr, I know that the Rx 580 meets the minimum requirements for vr and it’s not recommended, but I have the Rx 580 Gaming x 8g. I still strongly feel I should upgrade to a Radeon 5700 xt, I know that can do vr pretty well (I assume). I don’t know if my cpu would bottleneck it though, I herd it could be done. A lot further down the line I want to upgrade to an i7, 10th generation or above depending on when I get to it and it’s the same socket, if I have to change my motherboard anyway I will probably go for an AMD chip if there still beating intel, idk I will just look into it when I do upgrade. But my next upgrade is getting 4 case fans, It’s that and my pc will run absolutely quiet, I will be replacing it with the case fan I have in my case (Phanteks eclipse p400s). I currently have a Le Macho Grande RT Sitting atop my cpu, and under intense gaming it doesn’t go past 70 degrees C, so I can overclock if needed be. (A few more upgrades I though I should mention, a 1tb faster m.2 drive and a 3tb hdd (I found a reliable one around $60) and I would get rid of my current SSD, I just thought I should mention that just in case). What I’m saying is, Can do do vr well, I’m not asking if I meet the requirements because I know I can do, but could my pc handle be well. And if not would upgrading to a Radeon 5700 xt be a good choice? And is my current cpu good for vr?
My second quiestion, I think I have it all figured out but I want a second opinion: I’m thinking if getting and HTC Vive (2016), it’s a little pricey but It’s good, right? I would go the oculus rift s, it’s cheaper, but I have concerns: it has higher quality, but at the expense of 10 hertz, and I heard that’s were most people get sick. Also, I have had some experience with the Vive controllers, I love the design, but looking at the rift controllers it’s like Vive but all the buttons are in one place, I liked the feel of a trackpad, and a button to grab when I squeeze, and a trigger. Am I just wrong about the oculus controllers? Finally, I will be playing mostly steam games, I heard that oculus does support steam but you have to go through a certain process and they aren’t at the same quality. It’s a $100 difference, I would go Vive, but I worry I’m not having all the facts and am probably choosing wrong.
Anyway, that’s me on vr, sorry that was long, just a little nervous jumping into this, thought I needed some outside opinions. I would love to get started, I’m not that concerned with choosing a headset, just mostly my upgrade path for my pc. Also, any advice since I only started looking into this for about a week?
Intel i5-9600k
Rx 580 Gaming x 8g
MSI Z390-A PRO
512gb SATA III SSD
