[SOLVED] Is my pc running at good temps?
You are running very warm. I would set your exhaust fans to the highest speed you can stand with the sound. (I always run my case fans at top speed) What kind of cooler do you have on your cpu it is very warm/hot. You gpu is also very warm and you will probably see thermal throttling while gaming. Use MSI Afterburner and make your own fan curve to cool your card more aggressively .https://prnt.sc/1cpaign
Hey thanks for the reply. Will MIS after burner let me control all of my fan speeds?
All my PC fans, 120mm x 8, are wired direct to a 12v feed supply, they run fast all day long. I live in a country where 30+ is the norm....Xeon CPU temp runs at 54-58, previous Intel Q9400 ran at around 38-50*..
