[SOLVED] Is my pc running too hot or is this normal?
gameoverman2016
82
5
10,545
Hi all, I am running 2 monitors on my main pc, a 3440x1440 Acer Predator and a 1920x1080 monitor. My GTX 1080ti(evga ftw version) is running at 73c in games, and idling about 47c
Temps seem to have gone up since using an ultra wide monitor. Its also 88F outside, though about 70ish inside
My I7 6700K is also running at about 54c on core 1 and 2.
Is this normal temps? I know temps were like half this during the inter and on a standard 1080p monitor. Thx
EVGA GTX 1080ti FTW
I7 6700K
16GB ddr4 ram
Z170x mobo
h100i water cooler
650watt psu
Those temps are fine, as long as both CPU & GPU stay under 80C while under load then no worries.
BTW nice monitor, is that the 100hz or 120hz version?
