Is my power supply sufficient for my system?
TheCroak
9
Simply put...do I need to upgrade my PSU or is my current unit sufficient?
Here are my current system specs:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing
Motherboard: ASRock Z77 Extreme4 ATX LGA1155
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 760 2GB
Case: Corsair 400R ATX Mid Tower
Power Supply: Corsair CX 500W 80 PLUS Bronze Certified ATX12V
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
yes it sure is, you could replace the 760 with a titan and you still would be good, although i recommend seasonic parts.
PCPartPicker part list: http://pcpartpicker.com/p/4cTS
Price breakdown by merchant: http://pcpartpicker.com/p/4cTS/by_merchant/
Benchmarks: http://pcpartpicker.com/p/4cTS/benchmarks/
Power Supply: Antec High Current Gamer 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($64.99 @ Newegg)
Total: $64.99
(Generated by PCPartPicker 2013-11-11 03:11 EST-0500)
Total: $64.99
Actually 500 seems good. You can go for performance improvement or the modular approach. CX is the builder series from corsair. You can go for AX, HX or GS depending upon what you need. Otherwise 500 looks fine for this arrangement.
