Question Is my PSU compatible with RTX 4090 Suprim Liquid cooling?
tonywong2015
66
Hello, I have a Thermaltek RGB ThoughtPower 850W, is this the recommended PSU for that GPU or I need to upgrade to 3.0 ATX, PCIe 5.0 PSU 1000W??
Spec:
Intel i9 12900k
32GB Ram DDR5 5600Mhz
Motherboard Asus Rog Formula Z690
tonywong2015
66
Seasonic PRIME TX-1300, 1300W 80+ Titanium??
Thermaltake ToughPower
Spec:
Intel i9 12900k
Karadjgne
Ambassador
No. And since you'll need a larger wattage psu anyway, might as well get an ATX 3.0 standards psu of the right size since they are a direct fit for the 40 series, whereas All the ATX 2.0 standards psus that are currently made need adapters to fit the new gpus.
