Is my PSU enough for an FX-based system? (DEEPCOOL DQ750ST 750W 80+ Gold)
mtalarek
14
Hello Tom's. I am a PC building newbie, and running a AMD rig i built September 2016 for personal + budget reasons, i do not have performance issues on my rig, but my PSU with my FX rig is kinda spooky. Basically it's a DEEPCOOL DQ750ST, rated on Johnnyguru as i built spontaenously on a budget with unbalanced choices. In the end the gigabyte was the best board i could afford as well as the case i already got bought, and PSU and RX 470, i wanted to build a cheap AMD system to hold me pre-Zen and i am impressed with its results for the space (M-ATX) and VRMs. However, with a 4,2ghz compared to 4ghz on my FX 125W 6-Core FX-6350 i get very hot PSU during rendering and stressy loads. I know this PSU can get warm and has protection but it has Chinese capacitors by 'Elite' at 85c rated safe temperature. Since it has to stay under 40c for some reason, it will ramp up the fan gradually, i think this PSU is very smartly designed for a cheapo budget,, and its a bit noisy, but thats ok as long as it works. However it gets hot with AMD FX CPU, compared to same GPU with i5-2400 Dell rig i used to use. I noticed it increases during rendering loads but it never crashes or 'overheats' it just works. But it gets hot on the back of the rig. is that just FX power from the mobo, or the PSU not good enough?
7,5 out of 10 review on Kitguru 'Worth considering'.
My rig (i built it myself)
CASE: SHARKOON MA-M1000 MICRO-ATX VALUE EDITION
FAN1: BITFENIX 140MM SPECTRE PWM RED LED CASE FAN
FAN2(SIDE): SHARKOON ORIGINAL 140MM BLUE LED CASE FAN FOR VRM COOLING
PSU: DEEPCOOL DQ750ST
MB: GIGABYTE GA-78LMT-USB3 REV. 6.0 F2 BIOS M-ATX AM3+ AMD MOTHERBOARD
CPU: AMD FX-6350 SIX-CORE PROCESSOR @ OVERCLOCKED @ 4.2GHz @ 1,3650V
CC: ARCTIC FREEZER 13 CO 92MM PWM FAN
RAM: 2X8GB 1600MHZ DDR3 1,5V Crucial (Running in DUAL CHANNEL)
1x PCI-E: SAPPHIRE NITRO+ RADEON RX 470 4G GDDR5 1260MHz DUAL-BIOS GPU
SATA Bluray LG BD-ROM DVDRW M-DISC Non-4K Drive
SATA 2TB 7200RPM Seagate Hard drive (dual-boot with SSD for old OS and Linux Mint)
SATA to MSATA SMS200S3/120G Kingston 120GB SSD
Windows 10, Pro, 64-bit, Version 10.000, Build 14393
BIOS settings:
Voltage: Manual, DDR3 Voltage - Normal.
CPU VID Voltage : 1,3650V.
CPU NB VID: Normal.
LLC: Regular.
All power saving feature OFF except cool n quiet.
From looking at the specs of the PSU and the specs of your components I'd say you're well within the limits of your PSU. That PSU might not be the best out there but you've left enough head room that you shouldn't come close to maxing out that PSU.
