Is my system ok for an upgrade to a GTX 1080?
oliver.howe7
Power Supply: 500W Aerocool Integrator PSU 12Cm black fan Active PFC TW Caps - ACP-I500HG
Motherboard: MSI Z170A PC Mate Socket LGA 1151 VGA DVI HDMI 7.1 HD Audio
Processor: Intel Core i5 6600K Skylake Quad Core Retail - BX80662I56600K
Cooling: SilentiumPC Spartan PRO-B CPU Cooler HE924 - SPC121
Memory: 16GB DDR4 2400MHz (4 X 4GB)
Solid State Drive: SanDisk SDSSDP 128 GB
Hard Disk Drive: Toshiba DT01ACA 1TB
Current Graphics: MSI Geforce GTX960 2GB DDR5 - MSIGTX960-2GD5
Current OS: Windows 10 Home
Just wondering from those with a little more knowledge on specifics if this system would be ok to straight replace the gtx 960 for a 1080? If not which components would also need an uphaul and any recommendations would be welcome too :) I was also wondering if there would be any worth in running the two cards together with that fancy SLI mumbo I've heard does nice things in the past.
Thanks kindly for your time
i'd agree with AtomicDonut17, but would add, a couple of things.
You can OC your 6600k to offset most of the bottleneck in CPU intenisve games. And also your PSU isn't great. The 1080 needs a 500w PSU, and as most will tell you, you won't draw that much power anyway. However, if you OC you CPU, and get a 1080 i don't think that PSU will hold up. I can't find a review of that unit, but one or two on different models. I wouldn't rate it, and so would suggest a decent PSU like and EVGA GQ/G2 550w and then stick your 1080 in and OC that CPU. you will be good to go for a while yet.
