Is my system well balanced?
Jan 6, 2019
My system will be:
i9-9900K CPU
RTX 2080 Ti GPU
Z390 MoBo
850W 80 Plus Platinum PSU
16GB Trident Z 3200Mhz RAM
512GB 970 EVO Main Drive
2x 1TB 870 EVO Mass Storage
H220i CPU Cooler
(Insert Case)
Peripherals+Moniter:
XB271HU 1440 144hz Moniter
G903 Mouse
Razer Huntsman Elite
HyperX Black Mouse Pad
Razer Nari Wireless Headphones
Depending on the use, maybe.
I would not really call that a "balanced" system at face value though. Unless you have specific needs for the hardware chosen, then there are cheaper options at similar performance.
Do you do work that requires an i9 processor?
Any reason for the RTX series, especially a 2080Ti.
Lots of expensive storage, when it may not be needed.
Large PSU, with no indication of SLI this size is unnecessary.
Based on the peripherals you are gaming, in which case half of those components above can be brought down a bit.
