My motherboard is a Asus P8z68 Pro/Gen-V3 has a case mini pin 4 and I am looking for a side case fan size 120mm. I want a ball bearing fan that will last and not make too much noise. However, I don't want to spend a lot of money. I'm looking to spend $5-$20 on a good fan.
This is my case Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case http://www.newegg.com/Product/Product.aspx?gclid=CK_CkpOe2L8CFQIvaQodrhoA-w&Item=N82E16811147153&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Computer+Cases-_-N82E16811147153&ef_id=Uu3@zAAABBIYP9WI:20140722055627:s
I am thinking of getting this fan its $19.45 http://www.ebay.com/itm/Noctua-NF-S12A-PWM-120mm-4-pin-PWM-AAO-Frame-SSO2-Bearing-1200-900rpm-/171005339954?pt=US_Computer_Case_Fans&hash=item27d0b66932
What would be better case fans that use the mini 4 pin? Since I happen to have spare mini 4 cpu should I connect a 120mm fan to the case? Would it make a difference? Or should I get a splitter so I can have two 120mm case fans on the door of the case?
I was also looking at this fans, any opinions on them? Are they worse or just as good as the Noctua?
This one claims to have life expectancy of 70,000 more than any other fans I have seen and cost $6.79. Can this be true? http://www.ebay.com/itm/120mm-x-25mm-Double-Ball-Bearing-Server-Case-Fan-3-Pin-Power-12cm-x-2-5cm-/291186953680?pt=US_Computer_Case_Fans&hash=item43cc184dd0
http://www.ebay.com/itm/Evercool-EC12025H12BP-120mm-x-25mm-12v-High-Speed-Ball-Bearing-PWM-Cooling-Fan-/400725042035?pt=US_Computer_Case_Fans&hash=item5d4d12e373
http://www.ebay.com/itm/ARCTIC-F12-PWM-CO-Double-Ball-Bearings-Case-Fan-120mm-PWM-Speed-Control-for-24-/301164419430?pt=US_Computer_Case_Fans&hash=item461ecc5966
http://www.ebay.com/itm/bgears-B-PWM-120-BLUE-120mm-Blue-LED-PWM-technology-mini-4-pin-4-wire-2-ball-bea-/380941815893?pt=US_Computer_Case_Fans&hash=item58b1e6d055
http://www.ebay.com/itm/bgears-b-PWM-120-Black-120mm-PWM-technology-mini-4-pin-4-wire-2-ball-bearing-hig-/291180581482?pt=US_Computer_Case_Fans&hash=item43cbb7126a
