Is panel bit depth of Asus VZ229H monitor true 8-bit or 6-bit + FRC?
Jun 14, 2018
I checked on displayspecifications.com and it says as 8 bit but does not say "NO" under FRC. Normally on this website, they will mention whether a particular monitor is using FRC or not, if the monitor is using FRC they will mention as "yes" under FRC and if the monitor is not using FRC they will mention as "no" under FRC, but for this monitor the FRC section is missing. Appreciate if someone could tell me is this is a true 8 bit monitor or not. Thank you.
Just FYI, there's no visible difference between a "true" 8 bpc panel and a modern dithered one. Almost all 8 bpc monitors are 6-bit with dithering, because if they're going to put a true 8-bit panel in then they might as well implement dithering anyway to give it 10 bpc color depth.
