Question Is PC Air conditioning a thing?
ch33r
BANNED
Jun 13, 2010
316
4
18,685
And I mean... Without mods? Is there any air conditioning units that are designed to be mounted into a PC to give off really good cooling? Does such a thing exist?
never had a problem keeping mine cool on a simple air system :)
Wow that's rad. Is this a positive pressure build? What RPM do you have it set to at idle vs max loads? Were the performance gains worth the effort of this custom build vs an AIO cooler?.. ah nevermind I could never afford something like this even if I had the technical knowledge😔 props though mate.
Reactions: Math Geek
You could always get a small or portable AC unit and jury-rig a ducting system so the cold air is fed into the PC. Though the problem is that if you fire it up, you need to be sure that no condensation builds up on the components before powering on the PC.
But as people said, unless you're hitting a thermal limit, there's no performance benefit.
The ducting of A/C air into a case wouldn't likely get anywhere near cold enough for condensation to occur, but at the same time, isn't likely going to net you the long-term cold you'd hope. Air conditioning units are intended to cycle on and off and constant operation can cause ice buildup on the evaporator coils.
Sure, ducting in cold air is great for short term benchmarking, but isn't going to be a 24/7 solution. Plus, depending on model of A/C, you're looking at another $100-$500 depending on what you end up purchasing...that money could easily be better spent on a better cooling solution overall, or better/more powerful hardware.
I used an A/C unit to submerge into an insulated cooler full of glycol to use for my beer fermenting setup. There are 2 temp probes - 1 which runs into the beer inside a sanitized stainless dip tube (in the rubber stopper with the airlock bubbler) as well as another in the coolant tank of the Igloo cooler. When the beer reaches a specific temp (defined by the ale or lager fermentation profile I want) the circulation pump switches on and pumps cold coolant through the copper cooling jacket on the fermenter.
When the coolant temp reaches a certain temperature, the A/C unit kicks on until the coolant temp drops back to the temp I want.
If you replace the beer fermenter with a watercooling loop, you get chilled water cooling.
Reactions: hotaru.hino
