Is Pci-e 2.0 compatible with radeon r9 280x
tometom
17
So i want to upgrade my graphics card.
My GT630 is showing some issues and i want to play a lot more games than i can right now.
I choosed the AMD Radeon R9 280X.
My motherboard is the intel h81 that comes with the desktop Asus-M11AD.
I noticed that the pci-e version is not 3.0, as reccomended in the AMD website.
Will I have any problems during the transplant or in performance?
yah you are defiantly going to have to upgrade your power supply too. and to be honest i would get a 700W plus Bronze certified PSU. AMD cards are very power demanding and a lot of people under estimate them. just for my peace of mind i would not get a 650W even if people say it will work with it. but let me tell you one thing. if the computer only needs 650W and you are using a 700W the computer will only take in 650W and that extra 50W is there to not put pressure on your power supply and the power supply will even last longer.
yes you will you will not use the full power of the Graphics card. and in some cases you can hurt the graphics card too. I am wondering what kind of power supply you are using.
maybe i can find you a good graphics card that your power supply can support
My power supply is 350 W Peak,
Can you suggest a power supply for 80$-90$(50 euros-70 euros)?
