[SOLVED] Is RAM speed compatible with CPU and Motherboard
Meh, BioStar. Terrible website, there's a very short list on what RAM memory is supported on your motherboard. It doesn't mention the kit I linked but I have no reason to believe it wouldn't work. If you want to be safe, go with the Corsair kit, but know that the HyperX kit could perform better for a much better price.
Dang, Corsair RAM is expensive in Serbia. Yes, your CPU and that RAM kit will work together fine. But because it's so expensive, I'd advise you to go for this HyperX RAM kit instead:
https://www.tehnomanija.rs/it-shop/ram-memorije/kingston-fury-kf432c16rbk2-16.html
Same website, faster RAM (3200MHz) and it's cheaper. The only question is, is if the RAM kit is supported by your motherboard. Could you tell me which motherboard you have? If you do, I can find out if your motherboard supports the HyperX kit or not.
Sorry, i forgot to mention my Motherboard, my motherboard is A320MD ver 6.
