Hello
I'm gathering information on how to build my first home built PC. I read or watch a video at two sites already that said even if you plan on using your computer at stock speeds and not overclocking you should replace the CPU fan and never use the stock cooling that comes with your CPU. Both these sites went as far as to mention water cooling. So what's the lowdown are these sites correct? Should you at least immediately replace the stock cooling fan with a better one to keep your computer working for a long time? Or even as the sites suggest consider using an easy to use sealed water-cooler even for stock speeds? Please tell me what you think? Are the Intel stock fans particularly up to snuff or not? Are there any CPU cooling systems that are particularly easy to clean?
