[SOLVED] Is that disk dying? How to read nvme SMART?
houek
17
Hi guys, look at test of Corsair Force MP500 120GB. Write speed is terrible low, other parameters also looks bad.
I think I already accepted that my drive is dying, but I would like to know why. What can me a reason of that big differences between read and write? Or maybe is it some bad configuration somewhere?
@kanewolf
Also I've cheked firmware and it was latest verision.
Interesting. It shows the drive status as "FAILED" but no failed values listed.
I think you have to prepare for an unpredictable failure time frame. Might be in 5 min might be in 2 months. You should do appropriate backups and purchase a replacement. Then, on your schedule, replace it.
I would also contact Corsair support. This seems very odd.
You should check it with the Corsair tools https://www.corsair.com/us/en/blog/the-corsair-ssd-toolbox
Generic tools like Crystal Disk Info can get it wrong. Double check with the manufacturer's toolkit.
@kanewolf
I can't see the reason for the SMART failure, but I do notice the strange temperature sensors.
There is no temp sensor #0, but sensor #1 is reporting 382K, which is 109C. That's super hot. Yet the "composite temp" is only 325K (= 52C). This composite value is supposed to be a weighted average of some kind, so I'm wondering what it actually means.
