Thank you....jimThere are better pastes but generally you're talking within 3c performance wise.
Arctic silver is popular because its fairly cheap and readily available anywhere in the world, is easy to apply and performs well.
There are plenty of pastes that on paper have a better spec but in reality it doesn't make that much difference.
I use solely cooler master gel maker nano nowadays because it's what I have,I prefer it because it's thicker personally and needs to be manually spread. I wouldn't be adverse to using as5 though at all.
There's a list with thermal conductivity specs here.
Best thermal paste for CPU & GPU in 2025 - updated comparison and tier list for February
What's the best thermal paste for CPU & GPU setups? Thermal paste is often an overlooked component when configuring a new PC, either due to a lack ofwww.wepc.com
Thanks, I think I'll stay with what I have. I Don't OC.There are better pastes but generally you're talking within 3c performance wise.
Thanks for the list I appreciate this. JimThere are better pastes but generally you're talking within 3c performance wise.
