Question Is there a device to switch Display Port cables ?
bubra100
77
Hi . Please let me ask you a question .
I have a PC with 2 different video cards and I connect them to the monitor with a Display Port cable .
The reason I have 2 cards is because I want to have one that can be used for WinXP (since the later cards no longer support WinXP) .
So I would like to have a switcher to switch from one card to the other , because now I have each time to disconnect the cable from the one card and put it into the other .
Of course I am only interested to do this while the PC is turned OFF . I am only changing cards before starting the computer , not while it functions .
I found this on amazon , but I am not sure if this is what i need .
https://www.amazon.com/LINDY-Port-4K-DisplayPort-Switch/dp/B00ZK2S71W
I'm no pro but the item you have the link there for seems to be what you need. That is designed to have (2) Display Port Inputs that can be switched to a Single Display Port output.
My monitor supports 144 Hz . Are such devices going to reduce the refresh rate ?
To be honest I never got above 120 Hz in modern games , so I thing 12 Hz would be fine , but I don't know if the switchers affect the refresh rate .
The specs say it only supports 4K @ either 40Hz or 30Hz.
What resolution are you running?
If your only running 1080p it might support a higher refresh rate but you'd have to find the specs for that switch, it doesn't seem to list them.
There are many to choose form on Amazon, such as:
https://www.amazon.com/HDMI-Switch-...fix=DisplayPort+Switch,electronics,148&sr=1-3
I was using something like this to allow sharing a monitor for a laptop and PC.
The problem was when I toggled to the PC, the laptop moved all panels/images off the monitor and back onto the small laptop screen.
For 2 desktops you wont have that problem.
I paid around $11 a few months ago. Dirt cheap and worked easily enough.
Techole HS305 was what I got.
