Is there a difference between Sony G400 and G420S
G
Guest
Guest
I need to upgrade my sony 17 inch monitor, always loved sony monitors, jsut curious for the extar $50 is it worth it for the 420S monitor? Is it flatter? Or better quality or resoutions? If it just comes with speakers I dont care about that.
Thanks
differences are, the 420 is the successor to the 400. the 420 has a usb hub on it and can come with optional "multimedia" speakers. rez/refresh rates are the same.
well if luck is a lady, it explains why i have no luck :frown:
