So the pc uses 720 and im wandering if its harmfull for the parts of the pc if the pcu is higher then needed like by around 30 or 80 wat
download hwinfo,
install and open it=click run,
close the top window which is the system summary,
in the main window at the left top click "save report",
at the bottom of the next window check "Summary for Clipboard",
after that you'll see what's in the pc,
copy by clicking "copy to clipboard" and rightclick+paste in your next respons
its a pre made pc i just want to replace the 735 wat pcu 80 plus bronzeHow do you know the pc uses 720watt?
What kind of psu are you using? =maker+model+wattage.
What other pars in the pc? Can show by doing this,
In addition to the above, what specific PSU is this?So the pc uses 720 and im wandering if its harmfull for the parts of the pc if the pcu is higher then needed like by around 30 or 80 wat
Turbo-X Nemesis N560 Desktop (AMD Ryzen 5 5600X/16 GB/250 GB/RTX 3060 12 GB) | PlaisioIf we know what is in the pc can we determine if you really need such a high wattage psu.
You can use Imgur to post a picture here,use the "img" link.
Click "new post" ->choose "upload images" -> "browse" ->choose the picture and click "open" ->put cursor on the picture that you uploaded->choose "share links" and copy the img link,paste it in your next post.
Totaly 400w. Get a good 550w and you'll be fine.Ryzen 5 5600X RTX 3060 and one more thingy that uses up 70 wat
