Is there a special monitor inside a Mr. Do?
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Just curious. I'm repairing a Mr. Do and am wondering if there is a
special monitor in there. I have a very weird chassis installed and it
doesn't look right. Will G07's and WG monitors work in this machine?
john
G
Guest
Guest
John, I can tell you I ran one on a 25" k7000 monitor...
Don
NJ
G
Guest
Guest
I have one running on a WG. Mr. Do! gives negative syncs IIRC.
- Craig
G
Guest
Guest
Do you have to do anything special to make it run? Do you have to play
with the sync wires?
John
G
Guest
Guest
I don't believe so. I do remember trying to hook it up to pos sync, and
the screen was tearing quite a bit. Moved it to neg sync, adjusted the
vert hold, and wham-o! I don't have them tied together or anything.
White is vert sync, black is horiz sync, purple is ground.
- Craig
G
Guest
Guest
I *think* the stock monitors on dedicated Do's were different, 20" and by
odd-ball company IIRC. Anyone with more detail on the maker?? name escapes
me. I also remeber the chassis sitting on a shelf and not in a frame with
the tube, very odd set up.
G
Guest
Guest
Dedicated Mr Do monitors are made by Toei and are junk, pretty much good for
the dumpster.
http://www.homearcade.org/BBBB/monitor.html
Chuck it.
Ken.
"Atari_2600" <atariNOSPAM@twcny.rr.com> wrote in message
news:eek:5YAe.25749$e%5.9376@twister.nyroc.rr.com...
G
Guest
Guest
If it's an original factory shipped one (rare) then yes they had different
monitors. Mr.Do was mainly a conversion so you never know what you will find
in most cabinets. Standard negative composite sync so will work on WG and
EH fine.
"Baraka" <grus_jc@yahoo.com> wrote in message
news:1121199880.697416.255380@g14g2000cwa.googlegroups.com...
> john
