Is there a way to know if my CPU is dead without a mono speaker ?
Sep 13, 2018
8
My new build pc wouldn't boot (fans and leds went on). I am pretty sure that my CPU is dead (DOA). But is there a way to determine if it's actually the CPU that isn't working and not something else ?
I checked all the cables twice, started with one RAM stick and erased the RTC RAM.
Every bit of help appreciated.
My Components : https://pcpartpicker.com/list/YF7VfH
a speaker is a key diagnostic device, the motherboards main one in fact.
canned diagnostic speaker rant
The diagnostic speaker is the motherboards main diag feedback device.
the motherboard may be telling you where the problem is.
my speakers have this plug
http://images.crutchfieldonline.com/graphics/infolib/homelib/hSpeakerSpringClip.jpg
I use lamp wire but any stranded wire will do. literally any stranded wires. strip one end like so
http://www.antiquelampco.com/Shades/CordColors.jpg
attach the stripped end into the speaker spring clips on the speaker.
the other end of the wire should be trimmed like so the semi strip
https://wesbellwireandcable.com/images/cutwire.png
by doing a semi strip the wire case is now the socket.
plug one...
plug one wire to the first pin, and the second onto the fourth pin.
power on the system and listen for beeps
end canned rant
