Hello!
I dissasembled my Pc moved it and then reasembled it again. Before i put it in the case i set all the components in the mobo to check if i get good temps (so to see if if i had installed properly the CPU cooler). - Pc wasnt showing any image, so 1st thing i did i started moving the ram sticks and found out that the first two ram slots are not working anymore. Whatever ram stick i use or combination on the first 2 slots A1,A2 (closer to cpu) PC is not showing any image. Stupid me - probably i sorted something as i was trying to test without PC case.
I have 2 ram sticks 2x8gb DDR4 2133mhz. If i put them in the slots on the right (slots B1,B2) or only use 1 stick on either slot windows recognize them properly and PC boots normal, but they work in single channel mode.
So my question is, Is there a way to set my ram stick work on dual channel mode allthough they are placed on side by side slots? I searched on the bios but i cannot find anything.
Any response greatly appreciated!
Thanks!
Rig:
Mobo: AsRock Z170 Pro4S
CPU: Intel i5-6600k
Ram: Crucial 2x8GB DDR4 2133Mhz 1.2v CL15
Windows 10
Thanks!
Rig:
CPU: Intel i5-6600k
Windows 10
