Is there a way to use more than 100mbps while having the wifi on?
bananatatoe
Commendable
Oct 13, 2016
7
So basically my internet provider is providing me with a connection of 300mbps https://gyazo.com/45e88966ceb35b70e19db7a738ed894d
But if i connect the modem to the wifi router (a TP-link TL-WR841ND) i only get 100mbps trough the ethernet connection on my pc and i get like 85mbps on the laptop
https://gyazo.com/ae40f1bbd7201a8849282dfe8cbd4677
And i was wandering if there is a way to speed up my connection on the PC, i really dont care about how fast the wireless connection is, i just whant to speed my connetion on the PC
Thanks in advance
ok so i would need a router that has a 10/100/1000Mbps in order to use 300Mbps on my pc, so this router should be pretty good then: TP-LINK Gigabit Archer C2 Dual-Band
Anyway thanks again :)
