Hello
I have a fancy PC monitor which can easily rotate 90 degrees, and I’d like to start using it.
I had read that you can use Windows Shortcuts to easily switch back and forth, but these simply do not work. Someone seemed to think it had something to do with the GPU you own?
I have a Gigabyte 3070 Ti OC Gaming 8GB, other specs in my signature.
Here’s an example of folks saying it doesn’t work for them either…
https://shorturl.at/2SlHO
It’s easy to switch to Portrait, but super dicey and difficult to switch back (as the mouse is all in crazy mode like your brain is fried).
Is there an easier way to switch back and forth regularly without having to roll the dice and waste ages trying to turn it back to Landscape when I’m done in Portrait mode?
I’d definitely prefer shortcut keys or something similar, mouse shortcuts (I have a scroll wheel and side buttons), whatever ?
As a side note: I assume there is no way to make it so that Windows detects when the PC monitor has shifted a full 90 degrees in orientation, and automatically change it like a Tablet/Phone would ?
Thank you for your help
JR
JR
