hi there,
one of my 50m Flat cat7 ethernet cables had an issue and long story short, i had to cut the end in order to pull it out of a hole. Since it's a 50€ cable, i thought i might as well try to fix it and put a new Rj45.
There are those Tool Less adaptors which are neat but seems they cannot do a flat one, correct? Is there a specific kit for fixing a RJ 45 on a flat one?
Or, are these fused at the factory and there's no point trying to fix them? don't have tools at the moment so i'd have to buy everything from scratch and i just need to fix one cable at the moment.
thanks,
Gabrio
thanks,
Gabrio
