I am looking for a new HDMI cable and I notice some 'premium' versions with different shell material
Check this one for example:
www.aliexpress.com/item/1005005842428816.html
There are 3 versions:
PVC Shell Model
Zinc Alloy Model
Aluminum Blue
Is there any benefit in getting a cable with Zinc alloy or aluminum shell over PVC ?
I read somewhere that Zinc alloy material can help with heat dissipation, would this help in a PC?
If the price difference is like $5, is it worth to buy the one with zinc alloy or aluminum? I know image quality and stability will be the same, but I'm thinking more about durability and if heat dissipation really works/helps
PVC Shell Model
Zinc Alloy Model
Aluminum Blue
