Question Is there any way to tell the difference between a rx 580 ,and a flashed rx 480
May 1, 2019
I bought a used "rx 580" on ebay after checking the description again the specifications were changed to rx 480 is there anyway to tell if i got a rx 580 or rx 480 falshed to a rx 580 bios
What RmemberThe5th said.
Also GPU-Z has a 'Look up' button on the first tab (Graphic card tab) which looks up the card based on Hardware Id and subvendor Id which links to a page about the card on techpowerup dot com.
I'm not sure if the IDs change flashing the BIOS. If they don't that would be another clue as what GPU and GDDR memory you're dealing with and what the card really is.
