I'm planning my next PC with the goal of making it nearly silent during normal office use. My computing requirements are modest so I'm focused more on minimizing power & heat than maximizing performance. Today I'm researching 240GB SSD's.
I've been seeing complaints that some of the new NVMe drives are getting quite hot. The M.2 spec limits bus power to 7 watts, which may not sound like much, but it's enough to push temps to 80C and even 100C, presumably due to the small form factor.
Referring to power specs listed on newegg, I'm finding most NVMe ssd's have an active rating of 4 to 6 watts, about double the SATA III ssd's I checked. Although storage components spend a lot more time at idle, active power consumption is an important consideration for cooling system design and noise (fan) management (as well as device longevity, I would imagine). Given all the anecdotal reports of scorching hot ssd's, I was considering just going with a SATA III model.
Then I came across the WD Black ssd, which has an active power rating of a mere 135 milliwatts!! I assumed it was a misprint but WD's datasheet confirms this number. Then I saw another drive, the ADATA XPG SX8000, with an active power rating of only 333mW. What gives? All the other NVMe drives I checked have MUCH higher ratings. For example, the Samsung 960 EVO is rated at 5.3W active. I realize it has significantly better performance than the WD but I can't see how that would make a 40-fold difference in the power rating!
BTW, newegg doesn't list the power ratings for the highly touted MyDigitalSDD BPX. The product overview just says it consumes "less than 7W".
I suspect what's going on here is a lack of standards for how active power consumption is rated and reported. If so, I don't want to buy the WD Black for the wrong reasons (i.e., if reported power ratings aren't apples-to-apples). Can anyone here shed any light on this?
