Is there something wrong with my CPU temp?
iAvoid
Commendable
Jun 16, 2016
7
Is the something wrong with my cpu temperature? It's showing way too hot for idle. I'm not doing anything intensive on my cpu. It's using stock cooler and it is i5 4460.
It's showing 95~100 degrees for all my temps
https://postimg.org/image/vxy7j9m6p/
No, that's not normal. Have you checked the temp using other software to make sure it's not just that program?
Check that first, then if it still shows those temps try reseating the cooler. Make sure there's not any plastic bit still on the bottom of the cooler, and make sure it's properly fitted.
Poor airflow wouldn't cause such high temperatures unless it was left on full load for a considerable amount of time.
I checked with afterburner and it also shows around 100 degrees. But my cpu fan is not spinning.
