Is Thermaltake Berlin 630w powerfull enough for my system?
Jijix
24
Hello guys, I am going to switch to watercooling and i was wondering if my PSU will be powerfull enough for my full system. Here is what i have atm:
- i7 3770 @3.4 GHz
- 1x Sapphire Radeon R9 280X Dual-X
- 2x Kingston DDR3-1333 (667 MHz) 4GB (8GB total)
- Mobo ACER Aspire M3985
- HDD Seagate Barracuda 1TB Sata-III
- Optical drive, a random DVD-/+ RW
- 8 USB 2.0 and 4 USB 3.0
- PSU Thermaltake Berlin 630w
Now, i ordered the Corsair 750D case and the Corsair H100i water cooling. My question is, will this PSU be powerfull enough for this system? Am i running at the border between f-ing up the hardware and not? Will i be able to do some overclocking? I need some oppinions. Thank you guys in advance, Jijix.
Yheres a really good air cooler that works better than any of the premade liquid coolers. But that one should be fine just make sure it stays under 90c. 80c is best. But the overclocking, and 2 graphics, eh, you might want to get a stronger power supply
Edit. Sorry i missread. You only have one graphics. you might be okay with that power supply.
Link for overclocking temps
http://www.guru3d.com/articles_pages/cpu_cooler_roundup_2013_q1_review,11.html
Link for adding up watts (base idea)
http://extreme.outervision.com/psucalculatorlite.jsp
i only have 1 graphic card...dont want to...was wondering about the cpu, getting it a bit higher than 3,4GHz. (also i don't know how to do overclocking yet 😛 so thats just a though)
If you do overclock. Make sure you have someone who knows what there doing or read up and make sure you know what your doing. Like really make sure. Dont want to burn it up. I have the same cpu and plan on overclocking in the near future.
That cpu has a base clock of 3.4 boost to 3.6 i belive.
i think it goes up to 3,7. this is what aida64 says:
Field Value
CPU Properties
CPU Type QuadCore Intel Core i7-3770, 3700 MHz (37 x 100)
CPU Alias Ivy Bridge-DT
CPU Stepping E1/L1/N0/P0
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX
Original Clock [ TRIAL VERSION ]
Min / Max CPU Multiplier 16x / 34x
Engineering Sample No
L1 Code Cache 32 KB per core
L1 Data Cache [ TRIAL VERSION ]
L2 Cache 256 KB per core (On-Die, ECC, Full-Speed)
L3 Cache 8 MB (On-Die, ECC, Full-Speed)
CPU Physical Info
Package Type 1155 Contact FC-LGA
Package Size 37.5 mm x 37.5 mm
Transistors [ TRIAL VERSION ] million
Process Technology 22 nm, CMOS, Cu, High-K + Metal Gate
Die Size [ TRIAL VERSION ] mm2
Typical Power 77 W
CPU Manufacturer
Company Name Intel Corporation
Product Information http://ark.intel.com/search.aspx?q=Intel Core i7-3770
Driver Update http://www.aida64.com/driver-updates
Multi CPU
Motherboard ID ACRPRDCT ACRSYS
CPU #1 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU #2 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU #3 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU #4 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU #5 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU #6 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU #7 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU #8 Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3392 MHz
CPU Utilization
CPU #1 / Core #1 / HTT Unit #1 0%
CPU #1 / Core #1 / HTT Unit #2 0%
CPU #1 / Core #2 / HTT Unit #1 0%
CPU #1 / Core #2 / HTT Unit #2 0%
CPU #1 / Core #3 / HTT Unit #1 1%
CPU #1 / Core #3 / HTT Unit #2 0%
CPU #1 / Core #4 / HTT Unit #1 1%
CPU #1 / Core #4 / HTT Unit #2 0%
i'm not rly sure what to make out of this 😵
what would you sugest? not something that would blow my budget. something between 70€ and 130€
No such thing as overpowered. The psu will only deliver as much power as the system needs. The problem with the TR2 series is they are made od very cheap components, this leads to many issue like high ripple, poor voltage regulation, subpar or missing safety circuits, inability to provide anything close to its rated wattage. The TR2 series is also know to damage other hardware when they fail. I have seen a few TR2s completely wipe out a system when they failed.
eBay mostly.
It's a tier 2 PSU.
