Is this 1366 Build OK? would need help!
dwaight
149
Hi,
I'm looking to build a cheap gaming rig, since i dont want to spend 1000€-2000€+ on a build just yet, while Cannonlake is just around the corner i wanna keep it cheap.
so i was looking at a 1336 build, which is pretty outdated.. but does its job pretty wel as seeing on several video's/benchmarks. especially for the price.
i might need help on this build,or recommendations.
here it is :
Intel Core i7-960 Processor 3.20 GHz 8 MB Cache Socket LGA1366 $80.00
http://www.amazon.com/Intel-i7-960-Processor-Socket-LGA1366/dp/B0036Z6GH2/ref=sr_1_3?s=electronics&ie=UTF8&qid=1438367148&sr=1-3&keywords=960i7
MSI X58 Pro MS-7522 LGA 1366 $82.00
http://www.benl.ebay.be/itm/MSI-X58-Pro-MS-7522-LGA-1366-fur-i7-CPUs-GBit-LAN-RAID-6x-DDR3-Slots-inkl-Blende-/361295347035?hash=item541ee17d5b
Crucial Ballistix Sport 8GB Kit DDR3 1600 (PC3-12800) 240-Pin UDIMM Memory $44.49https://www.amazon.com/gp/product/B006WAGGUK/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Asus 24x DVD-RW Serial-ATA Internal OEM Optical Drive DRW-24B1ST $20.99
https://www.amazon.com/gp/product/B0033Z2BAQ/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ANU9P4C3SJQYZ
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2) $31.24
https://www.amazon.com/gp/product/B005O65JXI/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
WD Blue 1TB Desktop 3.5 Inch SATA 6Gb/s 7200rpm Internal Hard Drive$52.99
https://www.amazon.com/gp/product/B0088PUEPK/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
EVGA GeForce GTX 960 4GB Super SC ACX 2.0+ with Back Plate GDDR5 128bit,$$229.99
https://www.amazon.com/gp/product/B00UOYQ5LA/ref=ox_sc_act_title_1?
NZXT S340 Mid Tower Case CA-S340W-B1 (Glossy Black)$69.99
http://www.amazon.com/NZXT-Tower-CA-S340W-B1-Glossy-Black/dp/B00NGMIBUU/ref=sr_1_1?s=pc&ie=UTF8&qid=1438368894&sr=1-1&keywords=nzxt+s340
Total : $505.78 Without PSU.
Which should be 450€ When orderin from amazon.
i'm not sure if my optical drivers will fit in there since there is no 5' supported in the drivebay.. if i did read it correctly.
the only thing i would need is a PSU, probably around 600W?
i'm not sure about the psu, i tried PSU calculator, and it showed 550.
thoughts?
Thanks!
it's x3 three identical at a time for lga1366
Im gonna save up for Cannonlake and skip skylake.
and i just checked the cpu cooler and : Versatile all-in-one mounting solution supports most Intel (LGA 2011 / 1150 / 1366 / 1156 / 1155 / 775) and AMD (FM2 / FM1 / AM3+ / AM3 / AM2+ / AM2) platforms
so this should be good.
How do you mean exactly by the memory?
it can't be x2 2GB if i understand you correctly?
