Is this a good build? Help It My First
deckdog18
hey
i going to have a go at building a gamin pc and need some help. The main thing i be using it for is to play iracing and cod.
just wanting to see if this is a good start for parts
- 1 × ASUS PCE-N15 Wireless N300 PCI-Express Adapter SKU# AA81094
- 1 × Thermaltake TR2 S TRS-450AH2NK 450W 80PLUS ATX Power Supply SKU# AB80327
- 1 × Windows 10 Home 32/64-bit USB Drive SKU# AB64970
- 1 × Cooler Master MasterBox Lite 5 RGB ATX Case - Tempered Glass... SKU# AC06896
- 1 × Intel Core i5 7500 Quad Core LGA 1151 3.4 GHz CPU Processor SKU# AB94036
- 1 × DeepCool Gammaxx S40 120mm PWM Fan Multi-Socket CPU Cooler SKU# AB60210
- 1 × Seagate ST1000DX002 1TB FireCuda 3.5" SATA3 8GB NAND Desktop... SKU# AB85970
- 1 × G.Skill Ripjaws V 8GB (2x 4GB) DDR4 2400MHz Memory Red SKU# AB65667
- 1 × Gigabyte GeForce GTX 1060 Gaming G1 6GB Video Card SKU# AB84671
- 1 × Gigabyte B250M-D3H LGA 1151 Micro-ATX Motherboard SKU# AB94355
the budget is 1.6k aud right now it a total cost of 1530 so not to much room left.
Thanks for any help. Jack
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor ($279.00 @ Scorptec)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard ($179.00 @ Umart)
Memory: G.Skill - Ripjaws Series 16GB (4 x 4GB) DDR4-2400 Memory ($205.70 @ Newegg Australia)
Storage: Crucial - MX300 525GB M.2-2280 Solid State Drive ($202.00 @ IJK)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($85.00 @ Storm Computers)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card ($409.00 @ Umart)
Case: Deepcool - TESSERACT BF ATX Mid Tower Case ($48.00 @ Scorptec)
Power Supply: Silverstone - 500W 80+ Bronze Certified ATX Power Supply ($49.00 @ Umart)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($124.00 @ Shopping Express)
Total: $1580.70
Generated by PCPartPicker 2017-10-30 23:49 AEDT+1100
Barring the PSU (450 W is ok but not future proof), absolutely great build for a higher mid range PC, good job! Also, consider the RX 580 8G and it is same or lower price than 1060 6G. It offers slightly better performance and have better support for Vulcan API.
If possible try getting a 80+ 550-650W PSU from Thermaltake or Antec or Seasonic , if you can spend from that 70AUD or slightly stretch your budget . This is just to ensure that you would probably never have to invest in an PSU anytime soon, even you get a more power hungry GPU in future, or install additional components (say an extra HDD).
