Is this a PWM fan?
Hey
this is not a PWM fan.
This fan is a regualar 3 Pin Fan (Ground, Power, RPM sense)
PWN Fans do have 4 Pins (Ground, Power, RPM sense, PWN signal)
So you wont be able to adapter to or it or what ever 🙁
However you can tune the speed of the fan with voltage :)
Usually these fans run at 12V (in this case 12V = 700rpm)
if you do down to like 6V it should be half of that.
Hey
Non-pwm fan (3 pins).
