First things first, sorry for the long post but I don't want to just confuse people by not giving enough information since all loops are different. Now let me share with you my specs, my watercooling parts and some photos of the loop configuration:
View: https://imgur.com/gallery/kZTjzVM
Parts:
CPU: Delidded Intel Core i7 8086k running at 4.4 all cores
Memory: 16 GB DDR4 3200Mhz CAS14 Corsair Vengeance RGB Pro
GPU: RTX 2080Ti
Mobo: ASus Strix z390-I gaming mini ITX
PSU: Corsair SF750 Platinum SFX
Case: NZXT H110 Mini-ITX
Watercooling parts (all from EKWB except the coolant):
Soft tubing: EK-DuraClear 11,1/15,9mm 3M RETAIL
GPU Block: EK-Quantum Vector RTX RE Ti D-RGB - Nickel + Plexi
CPU Block: EK-Momentum ROG Strix Z390I D-RGB - Plexi
Radiators: x1 EK-CoolStream SE 240 and x1 SE 120
Pump Combo: EK-XRES 100 DDC MX 3.1 PWM (incl. pump) with and installed Heatsink also from EKWB THIS IS A LOWER POWERED VERSION OF A NORMAL DDC PUMP WITH JUST THE 4-FIN PWM FAN CONNECTOR TO POWER (NO MOLEX NEEDED) AND I CHOSE IT JUST BECAUSE MY LOOP WAS GOING TO BE VERY SMALL AND THE EKWB SUPPORT TOLD ME THAT THE PRESSURE HEAD OF IT WOULD BE MORE THAT ENOUGH (AND IT WAS ONLY 79 USD LOL).
Fittings and adapters: All Nickel plated from EKWB
Coolant: PrimoChill Ice - Low-Conductive Coolant (32 oz.) - Clear
Max temps on full load:
CPU: 84° C
GPU: 70°
As for other relevant data: This is my very first custom loop and it was only running about 3 months and a half mostly playing GTA Online and Halo MCC PC, I have no pets, and the PC is on a desk on my bedroom.
I did all the loop preparation procedures:
With all that context l begin:
Yesterday I decided to disassemble my watercooling loop because I could see in my acrylic monoblock that something was clearly growing inside the loop as shown in these pictures of the disassembled blocks:
View: https://imgur.com/gallery/dFSvinn
As you can see there are multiple stuff of different colors on each material of the loop, and this is where I need your help figuring out why and how this happened and also how to clean it out.
I just recently scrubbed most of the stuff with a toothbrush and 50/50 white vinegar and water and at least the CPU monoblock looks like brand new, except from one mark of the edge of the rubber gasket.
The thing growing inside in the acrylic is white, whereas the stuff growing on the nickel-plated blocks is this brownish sticky oily stuff, but not oily like slippery lubricant, but more like a thicker kind of oil.
This oily stuff was also on the inside of the threads of the fittings and adapters (all nickel plated). So it was not easy to clean, and on some of the fittings there is like a circled layer of white paste on them (as shown in the first photos).
The tubing is the most dirty of them all with clear signs of this stuff growing inside to the point where the soft tubing looks more like a yellowish plastic tube as shown in one of the images where is compared to a brand new tube.
The pump/res combo was the same as the acrylic top of the blocks, it had a yellowish layer of stuff which wasn't hard to wash off, but when I disassembled the pump it looked fine except that it also felt covered in the brown stuff.
Now, of all of the above parts they can be cleaned and washed out really easily, but the radiators can't. And this is the most worrisome part for me because I don't know what is growing inside of the radiators; as shown in the photos, this black/brown stuff is at least growing in the 240 radiator, whereas the 120mm rad looks fine from the inside.
I've read that 3 flushes with a mix of 50/50 water and vinegar and let it sit for 10 minutes should do the job, but I haven't tried anything just yet since first I wanted to be sure of exactly what I am dealing with.
So my three questions for you guys are:
Thanks in advance for your reply![Smile :) :)](/data/assets/smilies/smile.gif)
Parts:
GPU: RTX 2080Ti
CPU: 84° C
GPU: 70°
- Drained the rads with vinegar and water when brand new
- Flushed the brand-new loop & parts like 3 - 5 times with distilled water
- Leak tested the thing for +24 Hrs with no leaks at all
- What was the stuff growing on each of the parts?
- How do I clean and wash out all of the black stuff growing inside my radiators?
- How do I prevent this from happening again? even when I did all the mandatory stuff first
