Hi guys!
I recently discovered that my PSU was just too weak on the +12v rails to power my system + graphic card.
Here is the what the system is made up of.
motherboard
Asus P5K, P35, Socket-775, DDR2, ATX, GbLAN, PCI-Ex16
Memory:
Corsair TWIN2X 6400 DDR2, 2048MB CL5 Kit w/two matched CM2X1024A-6400 Dimm's
CPU
Intel Core 2 Quad Q6600 2.4GHz Socket LGA775, 8MB, BOXED m/fan
Graphic Card:
XFX GeForce 8800GTS 600M 640MB XT GDDR3, PCI-Express, 2xDVI/HDTV/HDCP, 112-SP
Hard drive:
Samsung SpinPoint T166 500GB SATA2 16MB 7200RPM
The PSU i was using now had only a maximum of 20 A on the +12v rail (single rail) which caused the entire system to fail a little into the gaming.
Read the guides and other suggested texts here on the forum, so I know that it's the +12v rail you should be looking for in a high end gaming system and not the total power wattage like I did before.
So I'm thinking in investing in a Antec TruePower Trio 650 - EC which costs aroud 200 USD here in Sweden. But the question I have is whether it has enough juice to power the system + 3 fans & 2 UV light tubes and the energy eating graphic card that requires a minimum of 26A on the +12V rail.
Thanks for your help!
motherboard
Memory:
CPU
Graphic Card:
Hard drive:
