So I noticed one of the fans in the AOI cooler is struggling to spin now, when it was ok before, I assume it might be dying, it wont go higher than say 200 rpm. I was thinking on replacing both fans so that they would match. I'm no expert on fans to be honest so I am unsure if this Cooler Master SickleFlow fans are ok or good to use on a radiator or if there is another better option. In the description mentions they are ok to use on radiators, but you know how some sellers are. Please let me know what you think.
Replacement fans: Cooler Master SickleFlow
The AOI I have : MasterLiquid LC240E RGB
Thanks
Thanks
