Hi, I recently purchased a new Motherboard and CPU. the rest of the hardware is from my previous build. I have gone from using Intel to AMD and have switched to a Ryzen 7 1800x with a Asus Crossfire Hero VI for my motherboard. The RAM is from my Previous build, Corsair Vengeance LPX DDR4 4x4GB 3000MHZ CMK16X4M4B3000C15.
The Issues I get is when ever I set it to DOCP Standard which sets the DRAM Frequency to 3000MHZ my machine will fail to POST and the RAM will get reset back to 2133MHZ. I can set it to DOCP 1 which sets the DRAM Freq to 3000MHZ as well and my machine will Boot fine, but then my CPU temp will idle at around 55°C-57°C and then ramp up to 70°C-77°C when doing simple tasks.
I have looked online and from the information I can gather it might be that fact that my RAM isn't compatible with RYZEN CPU'S. I wanted to just verify this with you guys and maybe get solution to my problem.
List of Components:
AMD Ryzen 7 1800x
NVIDIA GTX 980 Asus Strix Model
Corsair H1000i
2X WD HDD
2x Corsair SSD
1x Samsung SSD
List of Components:
AMD Ryzen 7 1800x
Corsair H1000i
2X WD HDD
2x Corsair SSD
1x Samsung SSD
