Question Issue with enabling Virtualization VT on Gigabyte Z77X-UP4 TH
ketrab
369
Hi,
I'm in need to spin up vm on my desktop using vm workstation 12 pro.
I am getting a VT-x is disabled error when starting up the VM.
https://ibb.co/mckCDtR
I have double check in bios that VT is enabled and as the error message says disable "trusted execution"
https://ibb.co/qxP0Njj
MOBO is running on the newest available firmware version F10B
Windows 10 64bit with i7-3770K (which supports VT-x)
https://ark.intel.com/content/www/u...-3770k-processor-8m-cache-up-to-3-90-ghz.html
Anybody got any ideas what else can I try?
As a last resort I've tried to put bios to default settings but still without luck.
Thanks in advance for any advise.
PS. Update - Task manager shows Virtualization disabled for some reasons. So I'm not sure if there is a firmware bug on mb or win10 combination?
https://ibb.co/ckKXwQb
I've also followed the instruction on how to disable hyper-v without luck. Check it out in case it works for you.
https://superuser.com/questions/1153470/vt-x-is-not-available-but-is-enabled-in-bios
There are three common culprits for the type of error the user is seeing:
  • VT-x is not enabled in the BIOS
  • The CPU doesn't support VT-x
  • Hyper-V virtualization is enabled in Windows
Since the user already eliminated the first two possible culprits, the next step is to open a command prompt as administrator and run the following command:
dism.exe /Online /Disable-Feature:Microsoft-Hyper-V
Lastly, I've downgraded my firmware(from 10b beta to f9) and virtualization started to show enabled. So had to be some firmware issue.
