Question Issue with PC BSOD's
devonkjesse
Commendable
Jun 9, 2018
43
Been getting alot of BSOD after my windows reinstall, here are the info
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 2019-08-26 11:53:18 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: magiczamboni
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>6</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2019-08-27T05:53:18.640029600Z" />
<EventRecordID>5152</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>magiczamboni</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">78</Data>
<Data Name="BugcheckParameter1">0x99</Data>
<Data Name="BugcheckParameter2">0x1f2537</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x4000000001ee437</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
</EventData>
</Event>
Happens from Kernal Power event, have not idea what to do
That can mess-up your Windows 10 installation. When installing 10 do not have any other physical drives connected. It may put some files on the other drives. Also after installing your operating system you should get all your motherboard drivers from their web site and install them second. Win 10 can install the motherboard drivers but they may be generic and not as good as the motherboard vendor drivers.
Ok, what are you using to install win 10? Downloaded to a USB stick? Disk? If it is downloaded to a USB stick the download could be corrupted and you need a new copy. Are you doing a clean install or an upgrade? That error usually comes from an Upgrade install. the most common reason for "Kernal Security Check Failure" is that the drivers you were using for the previous Windows version are not compatible with the new Windows version.
I checked my memory and every thing seemed fine, i needed to re install because it was the only way to get rid of the issue, but sadly it resulted in another as stated above. I use a samsung 250 evo, corsair vengence LPX 8gbX2 and a seagate 2tb HDD
I have this NEW issue which is POOL DETECTED MEMORY CORRUPTION, think its connected somehow.
