I'm having an issue whereby my PC will randomly shut down and restart, no BSOD, nothing in windows event logs. This happens mostly while gaming (mostly MMO, average / high settings, nothing demanding). Some times it will be fine for 5+ hours, some times it'll crash after 15 minutes.
I've run my own stress testing, and it's not crashed and I've taken it to a local PC repair shop and they couldn't find any issue with it after a week of having it on the bench.
I've checked temps and it's not overheating (GPU hotspot is hot at 88 degrees but its not spiking and that's likely due to the airflow not being the best, CPU is about 45 degrees under load).
Reliability monitor will regularly show the message "Windows was not properly shut down" even when shutting down normally.
I suspect the PSU is faulty but I wanted to check here to see if there are any other suggestions before I go and replace it.
Specs:
CPU: AMD RYZEN 7 - 5800X
GPU: MSI Nvidia GeForce RTX 3080 Ventus 3x 10g
RAM: Corsair Vengence RGB PRO DDR4 RAM 32GB 3600MHz
MOBO: Asus Prime x570-P
PSU: Corsair HX1000
Specs:
PSU: Corsair HX1000
