Issues and questions on compatibility
Faredoon
131
hey guys im planning to assemble a comp these are my specks
i5 4th gen 4690 processor
GA-H97-D3H gigabyte motherboard
ssd samsung evo 250 gb
8gb ram kingston hyper x fury 4 gb each
i ball 600 W power supply
dell ss40l screen
now my question is that is my motherboard compatible with my cpu yes i know the socket is 1150 for both but on youtube i saw a video which says its not compatible u got to update the bios and all
so now if i buy a stock cpu and motherboard put it together will it run good without a bios update ??
Without any BIOS update, that's what I meant, and yes it'd work. No issues.
@ meteorsraining what is w/o any bios update mean ??
are u saying that the i5 4690 will work with the ga h97 d3h yes or no ??
and hows the cpu and the board have u herd of any issues they give
What is your budget? You do not have a GPU listed either.
This is better:
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor ($223.99 @ Amazon)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard ($88.98 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($75.60 @ Newegg)
Power Supply: Rosewill Hive 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Amazon)
Total: $448.56
Generated by PCPartPicker 2014-10-05 02:53 EDT-0400
